Help with Receiver for 4 ohm speakers?
Discussion in 'AV Receivers & Amplifiers' started by danfrance110, Aug 27, 2004.
  1. danfrance110
    danfrance110
    Hi All,
    Looking to buy some m&k k4 & k5 speakers this weekend but I also need a good receiver to power them. I have no idea what I should be looking at but I have a £1000 budget for the receiver and don't mind if the receiver is new or second hand. Can anyone point me in the right direction? I was looking at yamaha 2400 and maybe Pio AX5i any opinions?
    Dan
  2. dts_boy
    dts_boy
    Nov 26, 2001
    2,615
    Manchester suburbs...
    +178
    for about £1k second hand you could pick up a denon avc1se possibly a 1sr. the M&Ks will sing on the end of this amp and will not struggle for power at all. as a new alternative the yamaha 2400 is a good performer, the pioneer might sound a bit bright in comparison (IMO)
  3. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    Pioneer don't recomend 4ohm speakers at all ,looks like the power supply isn't up to much.Nad or arcam might be a good bet, no doubt someone with more experience with £1000 amps will be on the next bus. :laugh: Sorry i'm wasn't much help :(
