MilleniumX
I am looking for a 55" TV. I read multiple reviews, most of which are very technical, but I would like some realistic feedback on performance which is visible to day to day use and overall experience instead of breaking up the various components and testing each one.
I will be using the TV for normal gaming (not hardcore), watching sports, and movies. Looking for a HD one, no need 3D or curved. I will not use much of the smart features as I will have BT. Price will be up to around £850, although would prefer something around £700 given most 4K screens can price at £900.
For example, I was at a friend's place, he had a Samsung 55" Series 6 3D smart TV (not sure the model number). When we were playing FIFA15, there was some visible motion blur which I felt was quite obvious. Although my friend did not tweak the settings, I would like to avoid that, or know if it can be fixed with some features turned on.
I have looked at the following:
- Samsung J5500 (£629)
- Samsung J6300 (£739)
- Samsung H6400 (£670)
- Sony W755C (£749)
- Sony W805C (£849) (a little pricey!)
- LG LF652V (£749)
Which one would you recommend? Any comments will be appreciated, or even recommending any new models! I only looked at Samsung, Sony and LG given the branding.
Thanks!
- Sony W755C (£749)
- LG LF652V (£749)
Thanks!
