beerglass007
Established Member
Hi all
Totally new to VR so please go easy
I've just ordered a Quest 2 64GB version, should I have ordered the 256GB version ? I assume I can play maybe 1 or 2 games and would need to delete before loading another ? How do you play and load the games ? Via cable or USB ?
Also the PC link cable is £90 [ wow ] I assume its not just a USB C and something special I cant make or buy cheaper
I have a PC with RTX 2070 S card want to play steam VR....I assume thats the cable how does that work ?
Can you download demos or 3rd party games and play from PC or direct off the internal memory ?
I held off buying a VR handset for years and nearly got the Rift S but assume this is a better option ?
I had PS4 VR and loved it but the camera, cables and tracking did my head in, I assume this is another level on from PS4 VR ?
Thanks in advance
Thanks in advance
