Help with pw7
Discussion in 'Plasma TVs' started by andrewb0000, Aug 19, 2005.
  1. andrewb0000
    andrewb0000
    Aug 13, 2005
    69
    i have bought a component board (TY42TM6A with BNC) i have connected it but im not getting a picture at all, i have tried 2 dvd players and its the same with both, i am using bettercables silver serpant component cable a denon 1910 dvd player and the other is a matsui recorder.
    anyone know what could be wrong
    cheers lee
  2. dvdchild
    dvdchild
    Aug 10, 2004
    4,481
    +125
    does the input let you switch to component. make sure that the card is also seated all the way in and screwed in. You may need to check settings aswell but my card went straight in with no problems or adjustments
    dvdchild
  3. andrewb0000
    andrewb0000
    Aug 13, 2005
    69
    yes it lets me choose component or RGB, ive tried both slots as well and no picture and there is no signal in top right corner. which settings may need checking?
    cheers lee
  4. andrewb0000
    andrewb0000
    Aug 13, 2005
    69
    sorted thanks to joe fernand, i forgot to set the dvd to component out :suicide:
    cheers lee
