Help with PW7
Discussion in 'Plasma TVs Forum' started by Andreas oakes, Mar 18, 2005.
  1. Andreas oakes
    Andreas oakes
    Dec 5, 2004
    228
    Aylesbury
    I have just installed a Pw7 and experiencing some difficulty getting it to display the on screen graphics from my amp the setup is,
    Tivo/Sky/Set top box connected via scart to a Keene electronics scart commander, then via scart to 3 phono rgb cable to a Pioneer VSX-D2011S amp into the component input, then from the component out to the component input on my DVDO Iscan HD scaler then to the plasma via the 15 pin D sub output into the D sub on the plasma.
    I have tried a component input to the amp and then component out to the scaler which if I set the amp to NTSC the on screen menu appears for an instant when when pressing the setup button on the amps remote.
    As my amp etc is in another room it would be good to get this working properly. Can anyone help.
    Also the image from my Thomson DTI 2300 is very bright and what I would call flarey even when the brightness and contrast are set low.
    Andy
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    the DTI2300 is horrible, as i have one i know the issues! when you say Scart to commander then RGB to pio then to HD i am at a loss to know why you are using 3 hubs......... and are you using an RGB>YUV converter?
  3. Andreas oakes
    Andreas oakes
    Dec 5, 2004
    228
    Aylesbury
    Sorry
    I may not have made the setup clear, basically the scart commander switches between the three inputs ( Tivo Sky Thomson )the output from the commander is then connected to the amp then to the scaler then on to the display.
    Andy
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    how is it connected to the amp (I dont see how you are converting RGBS to YUV or does the AMP do this????)
  5. Andreas oakes
    Andreas oakes
    Dec 5, 2004
    228
    Aylesbury
    I have decided not to bother going through the amp, I can get a picture from both the Sky box and crap set top box through the scaler but I still can't get tivo to work.
    Andy
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    ok assuming you are connecting RGBS from RGB scart to scaler (may be an issue with Tivo RGB, I'm not hot on Tivo I'm afraid) try composite to scaler, just to get Pic and check the Tivo is set to output RGB....
  7. Andreas oakes
    Andreas oakes
    Dec 5, 2004
    228
    Aylesbury
    I'll give that a go now
    Ta Andy
  8. Andreas oakes
    Andreas oakes
    Dec 5, 2004
    228
    Aylesbury
    It was set to RGB I think there is a problem with the Tivo
    Andy
