Help with puchasing DVD player upto £200?
Discussion in 'Blu-ray & DVD Players & Recorders' started by sasso62, Aug 29, 2005.
  1. sasso62
    sasso62
    Hi guys,
    Looking to buy a DVD player to go with my Phillips 9976 32" LCD.
    Basically want a 'plug and play' DVD player that does what it says on the tin ie. doesn't need the latest firmware upgrade or any technichal setting up.
    What will give me the best picture and sound for the money? The LCD has a DVI connector or I could connect using the component inputs?
    The Denon DVD-1910 seems a good bet so far?
    Many thanks
    Michael
  2. Drew2
    Drew2
    Jan 12, 2005
    699
    Tsukuba, Japan
    +32
    Why ask a question you've already answered?
  3. Del Boy Smiffy
    Del Boy Smiffy
    May 4, 2004
    6,096
    Yeovil
    +387
    Maybe because he wants more than one(his own) opinion.
    Even i worked that one out.
  4. sasso62
    sasso62
    ok ok, I did a little research, but is this the only DVD player I should consider? :eek:
