Help With ProV
Discussion in 'Projectors, Screens & Video Processors' started by windfall, Apr 20, 2004.
  1. windfall
    windfall
    Oct 19, 2003
    2,410
    48
    LFC Kop End
    +62
    Hi Guys
    I purchased one of these off another contributor to these forums.
    I have now received it, but I think I have made a mistake. :confused:
    Am I correct in saying that the ProV will only make a diff if I connect via VGA to my PTAE100?
    Cos if this is the case I may struggle as I need a 10 meter VGA conn and then I have to figure out how to get a link from the projector to my AV Rack! I was under the impression it had a Svhs-In and Out and I could benefit from this. But it only has SVHS In.
    :oops:
  2. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    Yes the ProV output is VGA only.
  3. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Do you mean sound ?? - You just connect your dvd player to your receiver as usual, connect the audio out of the ProV to one of the inputs of your receiver if you're using the built-in tv tuner......
    Sean G.
  4. windfall
    windfall
    Oct 19, 2003
    2,410
    48
    LFC Kop End
    +62
    No I meant vision. I read the manul for the PJ and it says the best pic quality is gained from a VGA input, the issue I have is routing a cable thats the real prob, may have to sell it on!! What a pain!
    Thanks for your help thus far though
    Tone
  5. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,268
    +158
    Tone,
    I'm sorry to hear that the ProV isn't exactly as you thought it was. As others have said, I'm afraid that the only way to connect it to your AE100 is by a monitor-type VGA cable.
    All I can say is that if you can work out a way to route a cable I think you'll find it's worth the effort; there really is a noticeable improvement in picture quality.
    Bert
    www.bertcoules.co.uk
  6. windfall
    windfall
    Oct 19, 2003
    2,410
    48
    LFC Kop End
    +62
    Hi Bert
    No probs I should have looked into this in more detail. I think I'll try and route a cable, will be off to Maplin to get a 10mtr cable and see if theres a way of routing it.
    Cheers for now
    Tone
