HELP WITH PRONTO EDIT 1.5 NEEDED
Discussion in 'Home Cinema Control & Remote Controls' started by burkey, Sep 29, 2001.
  1. burkey
    burkey
    I own a phillips Pronto which I edit on the PC with pronto edit version 1.5 . I also play around with the Marantz RC500 version 2.2 . This version has a function which lets you jump to a specific point and then return again after setting a suitable delay . Having made these modifications my pronto edit 1.5 will not open the file up as it states it is not a valid pronto file . Can I overcome this .
  2. Doubledoom
    Doubledoom
    The "jump to" setting is something that the marrantz can do in its software. you cannot do that in the same way with the Pronto.
    You shouldn't use the RCsetup with the pronto.
    However, the ccfs should be interchangeable.
