Hello all,
I have just bought a remote dimmer from B&Q, it works fine switching the lights on and off but it's also supposed to dim them if I hold the button down which it doesn't.
Has anyone else bought these dimmer switches and had the same problem, is so did they come up with a solution.
I should add that my room is L shaped and the switch is round the corner a bit.
Any help would be greatly appreciated.
Cheers,
Richard.
Cheers,
Richard.
