Help with popcorn hour and nmj
Discussion in 'Video Streaming Boxes & Services' started by dinoprada2003, Aug 20, 2013.
  1. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    4,035
    2
    LONDON
    +6,827
    Hi All,
    I wonder if someone can tell me how I can use nmj as one wallpaper for my internal sata hdd and my usb hdd without having to keep coming out of each one to go into the other when using nmj? :)
  2. halfelite
    halfelite
    Jun 11, 2012
    535
    43
    +106
    Use nmjtoolbox to combine them into one Jukebox
  3. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    4,035
    2
    LONDON
    +6,827
    Thanks do i download that to the popcorn hour or my pc?
  4. halfelite
    halfelite
    Jun 11, 2012
    535
    43
    +106
    It goes on your PC you only need to do it once. You set both paths for your local and usb drive and ti creates a db of both.
  5. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    4,035
    2
    LONDON
    +6,827
    Is there a idiots guide on how to do this? :)
  6. halfelite
    halfelite
    Jun 11, 2012
    535
    43
    +106
  7. Rom
    Rom
    Aug 16, 2007
    2,064
    116
    Sheffield
    +746
    It is fairly straight forward. There is documentation available to download from the NMJToolbox.net website.
    First thing to know is that it does not merge 2 databases into one. You start with one database as normal then NMJToolbox2 can add any number of drives/shares to that jukebox.
    You then have the option to scan with the NMJ or scan and add with NMJToolbox2 for all the shares that you have added.
  8. WeegyAVLover
    WeegyAVLover
    May 3, 2007
    4,795
    Scotland
    +1,789
  9. Rom
    Rom
    Aug 16, 2007
    2,064
    116
    Sheffield
    +746
    That is for YAMJ, not the NMJ :)
  10. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    4,035
    2
    LONDON
    +6,827
    Anyone know the default database path for the pch internal harddisk ? Im using nmtj v1 and it wont map it ?
    I have an a210
  11. Rom
    Rom
    Aug 16, 2007
    2,064
    116
    Sheffield
    +746
    Firstly, update your firmware, the 200 series has been updated to NMJv2 which is a lot better.
    What do you mean the database path to your internal drive? If you have created a DB on the internal drive you need to turn on samba in the PCH settings->nmt apps screen. Then you will be able to map a windows drive letter to the share folder. You will find the database in share\nmj_database folder.
