help with plasma before i throw it out window
Discussion in 'Plasma TVs' started by graze, Dec 22, 2004.
  1. graze
    graze
    I've just bought a vision 4230 and am trying to conect it to my sky didgybox
    on the back of the telly i have no scart connection that would be far to easy
    these are the connections i have on the TV
    1.RS-232C conecting terminal (input term for factory setup)
    2.PC signal input terminal (for pc analog signal)
    3.PC audio input term
    4.DTV,DVD input term (input term of Y,Pb/Cb, Pr/Cr for DTV,DVD)
    5.Composite video input term (for composite video term for audio signal)
    6.S-video input term (for Y/C signal)
    7.Video/Audio output term (connecting term for other video eqip, video signal;composite video signal
    8.speaker conection term
    9.power connector
    SKY BOX
    1.VCR scart
    2.TV scart
    3.RF out 2
    4.RF out 1
    5.Aerial in
    6.telephone line
    7.RS -232 (looks like a pc connection sort with pins)
    8.dish input
    9.power lead
    And there it is how on earth do i watch sky on my telly!! ermmm if i need a leads i didnt get with the telly can you tell me the names so i can buy em...
    That is ofcourse if i havnt had a breakdown by then.
    thanks for any and all help :suicide:
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,845
    Somewhere in South Yorkshire
    +5,078
    No audio input terminals (except 3)?
  3. Stephen Wilde
    Stephen Wilde
    Nov 15, 2003
    1,810
    48
    +93
    You need a converter from John Sim to get from the scart to the VGA input. There are many references to it on the boards. Best to contact JS direct.
  4. graze
    graze
    VGA input? where would that go?
    Begging your forgivness for my stupidity :(
  5. graze
    graze
  6. jasonl
    jasonl
    Aug 11, 2004
    147
    +3
    you can use a SCART-to-RCA adapter which will connect #2 of your digibox to #7 of yor plasma, you'll need the adapter and a set of RCA cables (same as the ones usually shipped with DVD players,VCRs etc)
    but to take advantage of RGB, use the JS converter as mentioned above, #2 of your digibox connects to this converter then from the converter you'll connect to #2 (for video) and 3 (for audio) of your plasma, here's a link to the converter http://www.av-sales.com/html/rgb_to_plasma_scrren_vga.html ,with this you'll need a SCART cable and a VGA cable
    there's also a similar converter as above but instead of connecting to #2 of your plasma, you'll connect to #4 (componenent connection), here you'll need the SCART cable and component video cable (plus 2 more RCA for sound in case), here's the link http://www.av-sales.com/html/rgb_to_component.html
    better to talk to av-sales so they can help you sort it out
  7. jasonl
    jasonl
    Aug 11, 2004
    147
    +3
  8. Stephen Wilde
    Stephen Wilde
    Nov 15, 2003
    1,810
    48
    +93
    RGB to VGA will give the best obtainable picture quality though.
