Help with pioneer
falcoron
Anyone know how to take the top menu off the screen? Pioneer blu ray player LX88
I must have pressed something on remote and now cant get rid!
tried resetting from start but no joy
Nothing in the manual
any pioneer owners know?
JayCee
Tried pressing the “Top Menu” or “Display” or “Pop Up Menu” buttons on the remote?
falcoron
Sorry doing in separate pictures
Pop up gives this, same when hit top menu
Hit Display button and turns off picture
gibbsy
If it's the same as my LX500 then you have to go to the info button. Click on it and the display should go off.
gibbsy
If that doesn't work then press display on the remote.
falcoron
Sorted
When I did a reset I just switched off and on again but no difference, I then turned off abs disconnected from mains fir 10 mins or so.
Reconnected turned on and did an initial start up from the beginning
Seems to have sorted it
gibbsy
It's the display button, top right on the remote. I'm running the LX500 right now and checked. Exactly the same display comes up, one press on, one press off.
falcoron
No it’s doesn’t work on this, if I press display while there is picture on the tv it turns off the display. I hit again and the display is on again but the top menu stayed.
No matter what I did, including what the manual says, it didn’t go away. I had to disconnect from the mains and then do initial start up as a new owner! Too bloody complicated compared to my wee Sony! But one hell of a picture and sound when playing
gibbsy
As that solved the problem. The player can be customised so often it's best to do a factory re-set and start from scratch. It can be somewhat involved to set up but my LX500 and the LX58 before it didn't need hardly any adjustments as they were/are so good out of the box. Some people like tinkering, I'm not one of them.
