help with Pioneer VSX 811
Discussion in 'AV Receivers & Amplifiers' started by Desperado, Feb 23, 2003.
Tags:
  1. Desperado
    Desperado
    is it normal that when playing Movies u can hear the surrounds fuzzing is the volume set to high in the Setting ?
    has somebody got the same problem?
    LMK
  2. EvilMudge
    EvilMudge
    Ok, first thing - which sound format are you listening to movies in? If the fuzzing happens on all formats the there is probably something wrong with the amp itself, but if it's one of the Pro-Logic modes then this may be due to the input you are giving the amp. Most amps only make noises like that if there is something wrong with the input signal or the power supply.
  3. Desperado
    Desperado
    volume on the rears was to high
