B
bertiespal
Hi, I'm new to the forums and am looking for advice with my CD changer. The Radio/Tape player works perfectly but the CDX-P1230S 12 CD player either jams when changing CD's or just fails to switch on at all. If I disconnect the plugs from the rear of the changer and re-fit, the system usually works but not for long. Any help would be welcome. regards, Jeff
