Help with picture settings please
Discussion in 'LCD & LED LCD TVs Forum' started by Shonte, Aug 24, 2005.
Tags:
  1. Shonte
    Shonte
    Aug 4, 2005
    138
    +4
    Hi all,
    I recently purchased the Toshiba 27WL56 LCD.
    I am constantly messing with the pic settings and cant find the perfect balance.
    Could someone recommend a good balance for general viewing from the following?
    Does someone have this or a similiar set?
    Backlight - 0-100
    Contrast - 0-100
    Brightness - 0-100
    Colour - 0-100
    Tint - -50 - +50
    Sharpness - -50 - +50
    Black Stretch - On or Off
    MPEG NR - LOW, Med, High
    DNR - Auto, High Low
    Col Temp - Normal, cool warm.
    Cinema Mode - On or off
    If any experts can give me some advice that would be awesome.
    Cheers in advance
  2. pjr918bmw
    pjr918bmw
    Aug 8, 2005
    394
    28
    +59
    Just got the 37WL56 and have also spent ages trying to get it where I want it. Would suggest that optimum settings will vary by TV location, ambient light, material being watched etc etc.
    Personally I've got it close enough and am now doing what I bought it for - watching DVD's not p**sing about with settings! :0)
    Mind you I've got a different problem see thread before yours. Good luck. Others may come up with something more constructive!
  3. Shonte
    Shonte
    Aug 4, 2005
    138
    +4
    could you give me a quick rundown of your settings?
  4. pjr918bmw
    pjr918bmw
    Aug 8, 2005
    394
    28
    +59
    For what it's worth....
    Tint and sharpness 0
    Black stretch on
    DNR and mpeg NR minimum
    color temp normal
    backlight circa 90 - have the dreaded buzzing!
    brightness 74
    color 51
    contrast 72
    Have fun
  5. jaydee
    jaydee
    Aug 16, 2005
    10
    My normal settings usually watching from a Freeview box are
    Backlight - 40 - Would like it about 60 but makes too much of a whine at that setting
    Contrast - 80
    Brightness - 50
    Colour - 50
    Tint - 0
    Sharpness - 0
    Black Stretch - On
    MPEG NR - LOW - off for Sport
    DNR - Auto, - off for Sport
    Col Temp - Normal
    Cinema Mode - On or off have never seen a difference either way
    The problem with getting acceptable settings seems to be very dependant on lighting conditions, my normal setting is a bit dark for bright daytime viewing, but fine for evenings.
    Do you get a whine from your backlight Shonte? Once the set is warmed up (say 30 minutes) if I mute the sound in a quiet room and change the backlight throughout the range I get a whine from it that is least bad at around 40 and worst at about 70. Just want to know if this is typical of all these sets or unique to mine.
  6. pjr918bmw
    pjr918bmw
    Aug 8, 2005
    394
    28
    +59
    I get the backlight whine - bloody annoying! I think it happens on all of them. Just turn the volume uo!
  7. Shonte
    Shonte
    Aug 4, 2005
    138
    +4
    Thanks guys.
    Yes I get the whine, its annoying but I just turn the backlight down and it goes!
