HELP WITH PHILIPS TV
Discussion in 'General TV Discussions Forum' started by dapem, Sep 28, 2001.
  1. dapem
    dapem
    I have a Philips 29PT828C TV. It displays the programme no.(in green) in the top right-hand corner. I switched this on accidentally and don't know how. Can anyone advise me how I can disable this?
  2. John Jennings
    John Jennings
    Aug 7, 2001
    282
    Uppsala, Sweden
    +5
    On most Philips remotes this is turned on/off by pushing the button with a little 'i' symbol on it. Don't know specifics about your model though unfortunately.
    Try holding the button for about 5 seconds if this doesn't immediately work.
  3. dapem
    dapem
    Thanks for the suggestion John, but it hasn't worked for me. Any other suggestions out there?
  4. atmoscinema
    atmoscinema
    Aug 4, 2000
    2,120
    Leicester
    +49
    Try holding down the button that first activated this,or any other,for severall seconds.
