First of all apologies if I've posted in the incorrect section, Im new here.
Ok, I'm trying to watch HD video on my HDTV from my PC.
My Current Hardware
PC - 2 x DVI outs (1 used for primary monitor, 2nd used used secondary monitor)
HDTV - 2 x HDMI sockets
1 x VGA socket
Proposed solution (the best I could think of
Buy 1 x DVI switch with 2 outputs and 1 input
Buy DVI to VGA converter
Buy VGA cable (for switch to HDTV)
From PC > DVI slot 2 >
Switch
> 2ND Monitor
> HDTV
So I would use my PC and 2 monitors as usual. When I want to watch HD video on my HDTV I'll press a button on the Switch which disables my 2nd monitor and enables the HDTV.
Is this setup okay? Please comment, or suggest a better set up.
As you may be aware, I am totally new at this. Thank you very much for your help.
Jessy
My Current Hardware
1 x VGA socket
Switch
> 2ND Monitor
> HDTV
Jessy
