Help With Panny TH42PW6B
Discussion in 'Plasma TVs Forum' started by GStormcrow, Mar 18, 2005.
  1. GStormcrow
    GStormcrow
    Mar 18, 2005
    37
    Hey. First post here :hiya:
    I am thinking of buying this plasma:
    http://www.richersounds.ie/asp/Viewproducts.asp?CatID=8&ProductID=4093
    I have never bought a plasma before and was just wondering if someone could help me with my setup. Here's a few questions
    1: Is this a good screen. Pros / Cons
    2: What extras will I need to connect the following:
    Playstation 2
    PC (Radeon 9800 Pro All in Wonder GFX)
    Creative DDTS-100 Decoder ( http://www.amazon.co.uk/exec/obidos...60782-5611050?_encoding=UTF8&m=A3P5ROKL5A1OLE )
    and Creative GigaWorks S750 7.1 Speakers ( http://www.amazon.co.uk/exec/obidos...60782-5611050?_encoding=UTF8&m=A3P5ROKL5A1OLE )
    3: Will the picture quality be good enough to replace my Samsung Syncmaster 710N monitor
    My gfx card has a built in tv tuner so I can watch tv on my monitor. So I'm guessing that if I can use this plasma as my monitor then I wont need a tuner. Like I said I am new to this and that is the setup I am thinking of getting. Any advice would be greatly appreciated
  2. GiZZeRR
    GiZZeRR
    May 24, 2003
    Edinburgh
    Just thought I'd say I have just bought the same plasma from them in Edinburgh but the black one instead of silver surround.
    Doing a major shift of amp,dvd etc to opposite side of the room to where I have mounted my screen and couldn't wait to get all the speaker wires re-routed under the floor so just turned the plasma on to see what the picture was like after I mounted it on the wall.
    Bloody hell !!!!!!!! it is fantastic :clap: I have Panny E55 dvd recorder and sky +. Fed the 10 meter component cable from the TY-42TM6Y component board I fitted to plasma to the E55, good scart from Sky+ to E55 and s-video from E55 to plasma component board.
    Don't know if this is the best way to do it but I fail to see how I can get a better picture doing anything different. Sky+ is way better than my Tosh 28"" wide screen and I have The Rock playing on DVD just now(no sound yet though) :rolleyes: and it looks superb.
    I'm going to be getting an Xbox to connect to it so need to look into connections for that but I'm sure if you go for either the series 6 or 7 then you will not be dissapointed.
    BIG thanks to all on the forums who answered any questions I had over the last month and helping me decide which plasma to go for. Best £1099 I have spent in a long time. :smashin:
    John
  3. GStormcrow
    GStormcrow
    Mar 18, 2005
    37
    Yeah it seems like a good screen from the spec list. Only thing is that I heard it has very limited connections. Want to make sure its compatible with my other stuff before I buy it and if it's not then what I will need to get to connect my other bits to it.
    I dont have sky digital or anything just a regular analogue pipe connection which will plug into my graphics card. So it really has to work with my PC
  4. GiZZeRR
    GiZZeRR
    May 24, 2003
    Edinburgh
    Yes from Richer sounds it doesn't come with any boards just the PC D sub 15pin but sound like thats all you need.....sure someone else will come in with suggestions.
    John
  5. GStormcrow
    GStormcrow
    Mar 18, 2005
    37
    Thats what I was hoping as I was hoping my graphics card could act as the tuner instead of buying the extra connection for it. Only thing is I'm not sure how it will function as a monitor. The resolution seems a bit low. I have mine set to 1024 x 768 on my pc. Hopefully someone will have some experience in these.
    Also came across this on my search
    http://www.krishav.co.uk/store/cat.asp?idCategory=496
    Now I'm wondering whether to go for the PW6 or PW7 or which will suit my setup better. They seem to be cheaper on that site than on RS so I can afford to go for the PW7 from that site if it is the better option. Also has anyone used that website before? Reliable?
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Krish are not unknown, others have used them to no ill effect AFAIK. Due to the low res the PW7 is not the ideal pC plasma, but if it's what you can aford then there are several threads about other PC users connecting them. When I do it I generally use 1280/720 as the PC res, this give no aspect ratio disortion. Some gfx cards now have this listed as a standard res, others you may need a free program called powerstrip, google for this. There is little difference to you between the 6 and 7 series plasmas, the 7 has a few more input boards available, and better implementation for the DVI board. I think I'd go for that if the price is good.
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
