Help with Panny NV-GS50B!!
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by ScorchedSoul, May 25, 2003.
  1. ScorchedSoul
    ScorchedSoul
    This is a rather embarrassing probelm, which i hope doesn't draw any flaming.
    I have just bought the NVGS50B camcorder, but i can't seem to figure out where the cassette goes!
    I have opened the cover, but then the slot where the cassestte looks like it is supposed to go is covered with some metal, with a sticker saying DO NOT PUSH.
    Basically i am stuck, and the above description is rubbish, i just hope someone knoes what I am talking about!
    Regards,
    Bob
  2. Duster
    Duster
    Dec 4, 2002
    421
    UK
    I dont own your Cam, but-
    That metal cover with the sticker on, should pop open and the tape goes in there.
    Have you attached a charged battery? as it wont open without power.
    Read the manual.
    If none of this helps, take it back to the shop.
    Good Luck:smoke:
  3. ScorchedSoul
    ScorchedSoul
    Duster, thanx for that. It was the battery thing, i didn't realise that the slot was mechanically powered, and there was no battery in it1
  4. Duster
    Duster
    Dec 4, 2002
    421
    UK
    No Worries:hiya: Glad to have helped
  5. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,365
    48
    +32
