Help with Panny E30
Discussion in 'Blu-ray & DVD Players & Recorders' started by gram99, Feb 5, 2003.
  1. gram99
    gram99
    I purchased an E30 today to archive my Sky+ recordings onto disc. Is there any way to archive them whilst viewing another channel on Sky? Whenever I use the copy button it will only allow me to view what the Sky+ Box is outputting to the Panny. The Panny is reording it no problem but I like the idea of archiving whilst I am watching something else. Am I barking up the wrong lampost?
    cheers
    Gram99
  2. DaveP
    DaveP
    Sorry, there's no chance of that I'm afraid. There is only one decoder in the box. I do mine overnight and before I set off for work in the morning.
    DaveP
  3. gram99
    gram99
    Thanks for the reply Dave.
    I thought there was two decoders in the Sky+ box? When you archive from sky+ does the queing systems work well?
  4. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    There are 2 tuners, but the programs are stored in encrypted form, and only one decoder, hence only one can be decoded and output at any time. No reason though why you can't record a program whilst you are archiving to watch later?
    A lot of poeple have been caught out by this, ie record a film and try to watch it after downgrading your package. You are no longer able to decrypt and view the film you recorded at a time when you had paid to be allowed to watch it
  5. gram99
    gram99
    Thanks guys, could anybody give me a quick rundown on how to hook up my connections. i am slightly confused as I want to be able to archive to DVD in RGB. My kit is: TV with two scarts though only 1 is RGB. Sky+ Box, Panny E30 and a Denon 1802 amp. What setup would allow me to watch sky in RGB watch DVDs in RGB and record onto DVDs with RGB. I also have a scart switch box if that is needed and that is compatible with RGB.
    cheers
    Gram99
  6. bobbles
    bobbles
    you will not need to use your switch box
    hook it up as follows
    SKY+ TV Scart (RGB OUT) -> DVDR RGB IN AV2 -> DVD RGB OUT AV1 -> TV RGB IN AV1
    This will allow you to watch in rgb through sky either by setting dvdr to AV2 whilst on, or by turning dvdr off, sky will then pass through dvdr in rgb
    Make sure you have set sky+ and E30 to RGB in the set up menus
    The VCR scart on the sky+ box is composite out only but it allows RGB pass through so you can attach an X-Box etc to the VCR scart and pass through an RGB signal through to the TV:devil:
  7. gram99
    gram99
    cheers bobbles, what DVD-R discs have you found to be compatible and cheap? Also how do you go about archiving your Sky+ programmes as I see from an earlier thread u2 have Sky+ :)
  8. bobbles
    bobbles
    I bought 50 of the yellow Trax -R from bigpockets
    less than 30, I work nearby though so I do not get chanrged P&P
    I am using -R to archive a variety of progs I have taped recorded on sky+
    This means I have to watch what I am recording in order to take off the ads, if only sky would allow a feature to do this automatically!
    I am making sure that anything I want to archive I only watch when later when I can archive, never live.
    The only way of editing out ads would be -RAM, expensive
    buying a DVD ROM capable of reading -RAM
    then a DVD Writer capable of writing onto -R
    again expensive but probably something I will do eventually as I would like some more interesting menus
    The third option is to buy a cheap Panny DVD Player capable of playing -RAM
    This would mean recording everything twice and a slight drop in quality
  9. gram99
    gram99
    They don't seem to have those in stock at the mo, what abot the bulkpaq Gen 3 disks? Or are there any in stock you would reccomend?
    thanks
  10. bobbles
    bobbles
    I've heard bulkpaq are not best suited for dvd films
    personally the other 50 in a tub would be better
  11. DaveP
    DaveP
    Gram99 to answer your other question:
    It works very well, it starts with a screen which lists the programs that you have selected. Then, as each program starts it gives you a brief synopsis so you can see what it is called and is about etc. Sadly you only get one "lump" on the DVD so you have to skip forward and hour to get to a program an hour into the recording. I prefer to archive one program at a time, that way you get "Chapters" on the start menu so you can select which one you want.
    HTH
    DaveP
  12. gram99
    gram99
    OK cheers guys, I went and bought 5 eperformance discs to test them so we will see. I think I will probably try and archive one at a time too. Probably do it overnight.
  13. gram99
    gram99
    well tried 2 eperfromance disks and they worked great. Hope they are all this good.
