Help with Panasonic NV-HD625 video set up
Discussion in 'Digital TV & Video Players & Recorders' started by mpnuttall, Jan 9, 2005.
Tags:
  1. mpnuttall
    mpnuttall
    Jan 9, 2005
    10
    Sheffield
    Ok, this is a long shot.
    I've just bought a secondhand Panasonic NV-HD625 video recorder and am trying to set it up.
    According to the instructions when first plugged in, auto setup should run. It doesn't. The display on the front of the recorder reads A1 and the time flashes at 0:00. I've tuned my tv through all possible channels and tried all the buttons on the video and remote and got nowhere.
    Does anyone have any ideas how I can sort this? Or is the player just broken?
    A great many thanks to anyone who can help
    Mark
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    The 'auto setup' will only run when the VCR is brand new and never been previously used.
    On my Panasonic VCR you can get the auto setup to run again by going into the menu and telling it to run the setup again.
    Hope this helps.
    Mark.
  3. andywilks
    andywilks
    Connect the video with a scart to the tv initially to be able to see the menu screens on tvs AV channel, then you can autosetup, set clock and set rf out channel
  4. mpnuttall
    mpnuttall
    Jan 9, 2005
    10
    Sheffield
    Thanks for the replies
    When I have the TV set up through a scart cable I can playback but cannot bring the menu or any other onscreen displays up. The basic play control functions on the remote work ok, and so I don't think it's because the remote is faulty.
    Any ideas?
    Mark
  5. steeled
    steeled
    Apr 23, 2002
    485
    28
    Maidenhead
    +54
    Hi Mark
    A couple of pointers for you.
    1. The menus only appear on the main SCART socket (I think it is labelled TV).
    If you use the other SCART then you will get the pictures and not the
    menus.
    2. To enable the modulator there maybe a switch on the back panel. If this is off then you will not get the VCR on the TV tuner.
    Hope this helps
    Dave
  6. mpnuttall
    mpnuttall
    Jan 9, 2005
    10
    Sheffield
    That may well be the best news I've had all day!
    Thanks, I'll give it a try tonight
    Mark
