Help with Panasonic DMR-HS2
Discussion in 'Blu-ray & DVD Players & Recorders' started by NickVardy, Jul 27, 2003.
  1. NickVardy
    NickVardy
    Hello all,
    A little help needed if possible for anyone who has a DMR-HS2. I have recently bought this and spent the other day setting it up. All was going well till I tried to hook up my VCR, in order to archive my old VHS tapes.
    I have it connected up as per manual. The DVD recorder AV1 hooked up to my tv and AV2 hooked up to my SKY digibox. The VCR is hooked up between the 2nd scart on thr VCR into the S-Video in on the DMR-HS2.
    I can record off SKY but anytime i play the VCR I can't get it to pick it up. I have set the Input select to AV3 as suggested in the manual.
    Has anyone else had the same problem or managed to get it working okay ? Would love to hear from anyone with ideas for me,
    Nick
  2. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    50 Rue St Georges, Paris.
    +32
    The 2nd Scart on your VCR may be an input only, not output to your HS2. The S-Video input will only accept correctly an S-Video signal, is your VCR S-Video ?
    Try a Scart into your SKY digibox directly from your VCR, switch SKY digibox into Standby, then try to record SKY as normal, the HS2 should record perfectly from your VHS tapes instead. :)
  3. NickVardy
    NickVardy
    Ah the VCR isn't S-Video to my knowledge so that may explain. Thanks for your suggestion, I shall try hooking it up as you say and give it a go..
  4. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    Don't forget that the output from sky is rgb and the vcr isn't. You will have to alter the hs2 input to suit.
    I find it best for occasional recording from a video to connect directly between the 2 and set the input to video, then reconnect after I am finished.
    Personally I keep the digibox rgb out connected to the hs2 in, the hs2 connected to the rgb in on the tv. Then because if you are recording an analogue program in the hs2, you cant view sky directly, I connect the second digibox out to the video in, and the video out to another scart on the tv. This gives an alternate way to view sky whilst the hs2 is recording, and I can playback occasional video recordings easily. I could even do a vhs recording from sky as well at a pinch, but rarely need to now.
