Help with Panasonic 32 PL1
Discussion in 'General TV Discussions Forum' started by ajsl, May 6, 2002.
Tags:
  1. ajsl
    ajsl
    May 6, 2002
    92
    Glasgow, UK.
    +6
    Hi there,
    I'm having some problems with my Panasonic 32PL1.
    Simply put, the on-screen graphics (channel indicators, volume bar etc) all flicker like mad when there is a signal present. i.e. they work fine if the aerial is unplugged (no TV signal) or on an AV channel with nothing connected (or the equipment is turned off). But as soon as I have a signal.. they're like flickering like mad!
    I've had the TV about 2-3 months, and it's only recently started to do this. I've tried unplugging the video and DVD players, changing leads etc but it makes not a jot of difference.
    The actual picture is superb and there's no problems there.. just the on-screen graphics that the TV itself generates have the problem.
    I'm hoping it's just something simple that I'm missing.
    Any ideas, or suggestions appreciated.
    Cheers,
    Alex.
