Help with Pacific freeview
Discussion in 'Freeview & YouView' started by SRD2004, Jun 16, 2005.
  1. SRD2004
    SRD2004
    I recently bought a pacific freeview box from asda. I got it all connected and it seemed to be working OK. However, now it appears to loose the digital signal....I turn it on and the now/next box appears for a few seconds and then the picture swtiches from digital back to normal tv. I've tried the connections and they seem to be fine. Any other ideas or does it sound like a faulty box?
  2. HarryAlffa
    HarryAlffa
    Jan 6, 2005
    61
    I've always found, like older PCs, that "rebooting" them helps. That is, unplug them from the mains for a few seconds.
