help with odd problem with Panny pw5
Discussion in 'Plasma TVs' started by Mouth on Legs, Dec 19, 2003.
  1. Mouth on Legs
    Mouth on Legs
    Jan 10, 2003
    77
    current system Sky+ ->marantz 4100 (dvd) -> JS RGB to YUC converter -> panny PW5
    all has worked well for 10 months
    suddenly the system has lost the ability to play R1 discs
    everything works well with R2 disc/sky but as soon as I put a R1 disc in the panny goes black and says "no signal"
    I seem to have narrowed the problem to the panny end of the chain. plugging the dvd into a normal telly works no problem. As far as I can tell the signal is arriving at the interface card, there is a definatley a signal on the Y component. Also if I connect the s-video from the DVD to the panny this works as well.
    Stuck now, looking for ideas please
  2. Jason S
    Jason S
    sounds like it's not detecting an NTSC signal on the component feed, although the S-video input is on the same card so I'd assume that it's using the same / similar circuitry.
    Could need the card swapping out / repairing (should still be under warranty).....
    Have you anything else that could generate an NTSC signal to test it out?
