Help with new tv!
Discussion in 'General TV Discussions Forum' started by hb100, Nov 6, 2001.
  1. hb100
    hb100
    hello
    having just purchased my first widescreen tv (tosh32zd09b) I have a couple of questions that you may be able to answer.
    Do all w/s tvs have geometry problems ? Mine seems to have a slight slant towards the right and curving on the left.
    If they all do should I expect a perfect set up on my tv?
  2. Doubledoom
    Doubledoom
    Widescreen and bad geometry go hand in hand. Some more than others.
    The more recent Toshiba sets are much better than the older model range. Yours is of the older model range unfortunatly.
    The good news is that the Toshiba service menu is one of the easist to use and the corrections can be made under warrenty or by yourself if you think you are up to it. The former should be the first action you take.
