help with new plasma PW8
Discussion in 'Plasma TVs Forum' started by horsegun, Oct 7, 2005.
  1. horsegun
    horsegun
    Aug 10, 2005
    69
    Bath
    Evening,
    Just setting up my new PW8.
    I have a component to RGB cable running from my dvd player and into the PW8. I can not get a picture, any ideas? I gave tried switching around the RGB/component option around in the set up
    thanks
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    have you done that on dvd and the screen? (do you mean component to vga?) it may be you need to connect your dvd via scart to somethingto get into teh menu and change its output to component
  3. horsegun
    horsegun
    Aug 10, 2005
    69
    Bath
    The dvd player gives me the option of changing it from progresive / RGB / Y C
    The telly gives me the option of RGB or companent.
    Which two should I use? I am sure I have tried them all but I could be wrong.
  4. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    telly should be component and dvd should be progressive or y c, i would think...can you see dvd setup menu?
  5. horsegun
    horsegun
    Aug 10, 2005
    69
    Bath
    All sorted now and it looks Awesome! :D Very happy with it!
    I didnt press enter on the DVD player while scolling through the options, that was the problem.
    Thanks for your help :)
  6. maxl
    maxl
    Mar 7, 2005
    135
    +3
    Dude, post some pics :)
  7. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    good stuff!!...enjoy
