Help with new camcorder :)
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by biccus1, Oct 16, 2004.
  1. biccus1
    biccus1
    Aug 23, 2002
    1,448
    Great yarmouth
    +31
    I think its time for a new camcorder but which one to go for is just too much to take in so was hoping for some help :)
    At the mo i have a jvc gr-dvx8 which is fine except it will no shoot in low light which is anoying sometimes!
    Also for some reason when i use pinnacle 8 for capture it does not reconise the stop gaps in the movie so everytime it it paused it should start a new frame section but it never does so i end up having to set my own every 3 mins or so! (which is not good when editing as i end up with 60 mins of footage in one strip)
    So what do you all reccomend budget around £500
    shane
    Sony DCR-PC105E
    This is the only one i have looked at so far bit over budget?Unless somebody knows somewhere cheap for it :)
  2. biccus1
    biccus1
    Aug 23, 2002
    1,448
    Great yarmouth
    +31
    Nobody :(
  3. biccus1
    biccus1
    Aug 23, 2002
    1,448
    Great yarmouth
    +31
  4. biccus1
    biccus1
    Aug 23, 2002
    1,448
    Great yarmouth
    +31
    pros and cons for the sony DCR-HC30 or DCR-HC40 I think its only the stills between these two but what is the camera like overall?
    Is it any good in low light?
    Plz help i need a new camera before xmas!
    shane
  5. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    HC 40 or PC105
  6. biccus1
    biccus1
    Aug 23, 2002
    1,448
    Great yarmouth
    +31
    Is the pc 105 still avalible or has it finished now and if so what has replaced it?
    do they both do the same except the shape issue?
  7. biccus1
    biccus1
    Aug 23, 2002
    1,448
    Great yarmouth
    +31
    What about the Sony DCR-PC109/E ?
    Is this the one which replaced the pc 105?
  8. biccus1
    biccus1
    Aug 23, 2002
    1,448
    Great yarmouth
    +31
  9. biccus1
    biccus1
    Aug 23, 2002
    1,448
    Great yarmouth
    +31
    looks like it will be the 109 then any last thoughts on this?
  10. Centurion
    Centurion
    If your shooting in low light you need a camera with a large aperture ie a smaller F number. My JVC GRDV700 has a F1.2 aspherical lense making it a good low light cam. Keep an eye out for the F number!
