Help with New All-In-One
Discussion in 'Home Cinema Buying & Building' started by stumpy_uk, Oct 25, 2004.
  1. stumpy_uk
    stumpy_uk
    Aug 11, 2003
    199
    In front of My PC
    +10
    Like a few on here I have the Sony DAV800 and the sound has gone on DVD playback completely, I like my speakers and therefore don't want to change them.
    I am also getting a plasma so would like component out so that connection is easy. Does anyone know of a system where I can use my speakers and also has component out as all the Sony ones tend to come with speakers and cost over £600 which I don't really want to spend if I can help it.
    Stumpy
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Hi mate did you sort out the wall mounting? i think you would need to look for another newer sony.... Not great on SOny but most all in ones cant use speakers with any other amps etc.... sateliites might be ok but will need a new sub
