Help with new 42PZ85
Discussion in 'Plasma TVs Forum' started by saleshark, May 30, 2008.
  1. saleshark
    saleshark
    Oct 25, 2006
    97
    Hi All
    I took delivery of my first Plasma yesterday:clap: and have set it up as best I can.
    Sky SD - Cinema, Colour warm, IFC off
    PS3 - As above with IFC on
    DVD - As with Sky
    My first question is should I have overscan on on my sky input?
    The second question is how do I control whether the TV deals with upscaling or the source.
    I want to use the PS3 to upscale when watching DVD's do I have to change anything on the TV?
    Also does anyone know what the code is for the Sky remote to get some control over the telly and what do I have to press to enter the code??
    Thanks for your help.
  2. YellowSphere
    YellowSphere
    Dec 2, 2007
    4,448
    103
    +471
    The TV automatically scales anything input which isn't 1080p. So basically, if you want to bypass its scaling, that's the resolution you input, with picture overscan set to off. Whether or not that's better than the built in scaling is down to your own judgement, though I wouldn't be surprised if it was in this case.
