Help with Netgear router deperately needed :(
Discussion in 'Networking & NAS' started by Shoki, Mar 25, 2006.
  1. Shoki
    Shoki
    Oct 25, 2005
    948
    28
    +54
    Hi all, hoping someone can please save my sanity here as i'v spent the last six hours trying to set up a router and it just aint having any of it :(
    Bought a Netgear DG834G adsl wireless router today with the idea that i could connect my xbox 360 to live without having to turn the pc on, currently have the xbox connected to pc and pc connected to usb modem. I'v run all the setup wizards that came with the router, checked all the settings and it still wont let me view web pages or send or recieve email, during the setup i have the option to test, which works and says i'm connected and its then supposed to connect to netgears home page, but i just get "page cannot be displayed" :( I'v actually had the xbox connected to live and seems to work fine through the router but the pc just wont connect to the internet, anyone have any ideas what i'm doing wrong? :lease: :lease: :lease:
  2. and30280
    and30280
    Mar 31, 2005
    1,153
    38
    +13
    Hiya
    Its not all about plugging it in and away it works, You need to setup the modem router to you IP provider and tell it your account and password so that it can log you onto the network as your standard modem would.
    I had excactly the same problem with mine till i called belkin and they talked me through the above
    Hope it helps
    Andrew
  3. Shoki
    Shoki
    Oct 25, 2005
    948
    28
    +54
    Thanks Andrew but thats exactly what i thought i had done, all the diagnostics say i have a connection, the xbox connects through the router so i know it does work and must be logged onto my isp, but internet explorer does nothing, followed the manual over and over and scanned through the troubleshooting guide but nothing seems to work :(
  4. and30280
    and30280
    Mar 31, 2005
    1,153
    38
    +13
    Give em a buzz on the phone
    Andrew
  5. Shoki
    Shoki
    Oct 25, 2005
    948
    28
    +54
    Yep guess thats gonna be the next step :(
  6. Shoki
    Shoki
    Oct 25, 2005
    948
    28
    +54
    Well after nearly an hour on the phone to customer support, and trying everything they said, it's still a no go, and they informed me that they could'nt configure the router :( :(
  7. andrew1810
    andrew1810
    Apr 4, 2004
    1,180
    North East
    +55
    Does the xbox work through the router?
    On the pc, try:
    Start - Run - cmd (enter)
    Type "route print" and press enter
    Then if you paste the output here I'll be able to see if there is a problem there.
    Also, whilst in the command prompt type "tracert" and see at what stage it times out
    Andrew
  8. Shoki
    Shoki
    Oct 25, 2005
    948
    28
    +54
    Thanks for your help :) yeah the xbox works fine just the pc, ok hope thi smeans something to you.
    route print
    Interface List
    0x1 ........................... MS TCP Loopback interface
    0x60002 ...00 30 bd ba d4 27 ...... Realtek RTL8139 Family PCI Fast Ethernet NIC
    - Packet Scheduler Miniport
    Active Routes:
    Network Destination Netmask Gateway Interface Metric
    0.0.0.0 0.0.0.0 213.162.97.65 192.168.0.2 20
    127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
    192.168.0.0 255.255.255.0 192.168.0.2 192.168.0.2 20
    192.168.0.2 255.255.255.255 127.0.0.1 127.0.0.1 20
    192.168.0.255 255.255.255.255 192.168.0.2 192.168.0.2 20
    224.0.0.0 240.0.0.0 192.168.0.2 192.168.0.2 20
    255.255.255.255 255.255.255.255 192.168.0.2 192.168.0.2 1
    Default Gateway: 213.162.97.65
    Persistent Routes:
    None
    Typed tracert abd this is what it came up with, not sure if this is what you were after though.
    Usage: tracert [-d] [-h maximum_hops] [-j host-list] [-w timeout] target_name
    Options:
    -d Do not resolve addresses to hostnames.
    -h maximum_hops Maximum number of hops to search for target.
    -j host-list Loose source route along host-list.
    -w timeout Wait timeout milliseconds for each reply.
  9. andrew1810
    andrew1810
    Apr 4, 2004
    1,180
    North East
    +55
    Ok, looking at that it has your default gateway as a different ip address from the router.
    Right click on My Network Places and click Properties
    Right click on the network connection and again click properties.
    Click on TCP/IP and click properties.
    Try setting both of these to automatic.
    Then in a command prompt, type ipconfig /release
    Then type ipconfig /renew
    When that is done type ipconfig /all and post the results here
    Also might be doing another route print too
  10. The Dude
    The Dude
    May 21, 2004
    6,772
    Beverley, East Yorkshire
    +3,241
    have you checked that IE is set to use the existing LAN connection, as opposed to always dialing the connection for the USB modem...?
    If the Xbox works and the PC doesn't, looks like just a SW problem.....
    I'm guessing you use IE, and Outlook Express for Email?
    (OE takes it's connectivity settings from what is configured in IE)
  11. Shoki
    Shoki
    Oct 25, 2005
    948
    28
    +54
    Ok Andrew, entered everything you mentioned and the results are:
    ipconfig/release
    Windows IP Configuration
    Ethernet adapter Local Area Connection 2:
    Connection-specific DNS Suffix . :
    IP Address. . . . . . . . . . . . : 0.0.0.0
    Subnet Mask . . . . . . . . . . . : 0.0.0.0
    Default Gateway . . . . . . . . . :
    ipconfig/renew
    IP Address. . . . . . . . . . . . : 192.168.0.2
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Default Gateway . . . . . . . . . : 213.162.97.65
    ipconfig/all
    Host Name . . . . . . . . . . . . : steve-comp1
    Primary Dns Suffix . . . . . . . :
    Node Type . . . . . . . . . . . . : Unknown
    IP Routing Enabled. . . . . . . . : Yes
    WINS Proxy Enabled. . . . . . . . : No
    Description . . . . . . . . . . . : F5D5000, PCI Card/Desktop Network PC
    I Card
    Physical Address. . . . . . . . . : 00-30-BD-BA-D4-27
    Dhcp Enabled. . . . . . . . . . . : Yes
    Autoconfiguration Enabled . . . . : Yes
    DHCP Server . . . . . . . . . . . : 192.168.0.1
    DNS Servers . . . . . . . . . . . : 192.168.0.1
    Lease Obtained. . . . . . . . . . : 26 March 2006 13:14:53
    Lease Expires . . . . . . . . . . : 27 March 2006 13:14:53
    Dude, yeah i have "never dial a connection" selected, in the console settings of the xbox when i run the "test live connection" it passes all the tests and works perfectly.
  12. andrew1810
    andrew1810
    Apr 4, 2004
    1,180
    North East
    +55
    Ok,
    Right click on My Network Places and click Properties.
    Then right click on local area connection 2 and click properties
    Click TCP/IP and click properties
    Click use the following IP address and input the following
    Box 1: 192.168.0.2
    Box 2: 255.255.255.0
    Box 3: 192.168.0.1
    Then try accessing the internet to see if that fixes it, if it doesn't, can you try another route print and print the results?
  13. Shoki
    Shoki
    Oct 25, 2005
    948
    28
    +54
    Still no go :(
    route print
    Interface List
    0x2 ...00 30 bd ba d4 27 ...... Realtek RTL8139 Family PCI Fast Ethernet NIC - P
    Active Routes:
    0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.2 20
    Default Gateway: 192.168.0.1
    Persistent Routes:
    None
    Really appreciate your help here :)
  14. andrew1810
    andrew1810
    Apr 4, 2004
    1,180
    North East
    +55
    When you log into the router in a web browser, what address do you type in, it is 192.168.0.1?
    In a command prompt, try tracert www.google.co.uk
    That will show where the connection is failing.
  15. deksawyer
    deksawyer
    May 26, 2005
    1,641
    Fife, Scotland
    +132
    Also, try changing the DNS Servers to at least 1 of the following;
    194.72.6.52
    193.113.212.38
    194.72.6.57
    194.72.9.34
    194.74.65.68
    D.
  16. Shoki
    Shoki
    Oct 25, 2005
    948
    28
    +54
    Thanks alot for your help gents, really appreciated your time, but after completely spitting the dummy this afternoon i returned the router and bought an ethernet modem which seems to be doing the job (crosses fingers) So cheers again :)
