Hallsy
I bought a wall mount a while back, but didn't fit it at the time, it's the same as this one:
* LLOYTRON LCD/PLASMA TV WALL MOUNT 32"-60"* BNIB on eBay, also, Wall Mounts Brackets, TV Accessories, Consumer Electronics (end time 29-May-09 21:13:26 BST)
Now, I have the instructions - usual thing, the bars attach to back of TV, which rest onto the wall mount. A locking bar is slid in along the bottom to stop it falling, and can be padlocked. Thing is, this doesn't lock the mount tight, you could still slide the TV along if you wanted to.
On the side of the bars on the TV there are a pair of small plates with screws in, which i assume are used to lock the mount tight, so that it won't slide.
Trouble is, they are not mentioned in the manual, I have a recollection of their being an ammendment mentioning them, but I can't find it.
I'll take some pics in a bit if it isn't clear, but does anyone know what I mean, and what you are meant to do with them?
If I put them one way around, they lock it up, but protude further back than the wallmount, and so wouldn't fit against the wall. Fit them the other way around and they fit flush, but the locking back won't go in as they block the lower part of the slide hole.
