Help with My Philips 4341 - Picture included
Discussion in 'Projectors, Screens & Video Processors' started by TiSwAs, Jul 10, 2005.
  1. TiSwAs
    TiSwAs
    May 2, 2005
    387
    Blackpool
    +20
    Hi i have a philips lcd projector and after 2 months of not using it i've turned it on and i'm getting a problem down the sides of the picture...
    On the Left is it BLUE
    On the Right is is YELLOW
    [​IMG]
    Can anyone advise what the problem is... do i need a new bulb?
  2. ZippyCat
    ZippyCat
    Aug 9, 2004
    573
    28
    +22
    It appears to be either heat damage to the LCD panels or the prism block assembly. Unfortunately this is likely to be an expensive affair, so you may decide to upgrade the projector.
  3. TiSwAs
    TiSwAs
    May 2, 2005
    387
    Blackpool
    +20
    Many thanks for your reply, just with any replacement items in a projector it's gonna be alot easier to replace it! just nice to know whats up with it.
