help with my new sammy please
Discussion in 'Televisions' started by riprse, Apr 4, 2005.
  1. riprse
    riprse
    Apr 4, 2005
    1,225
    63
    +115
    hi all , ok as a newbie to all this, im hoping you guys will help me out .
    iv just git a sammy dlp & i want to get the best out of it, but i have no idea where to start. all this hdtv & hdmi stuff means nothing to me . i guess, i need to get some cables for hdmi & a new dvd with hdmi .but to be honest im pretty clueless . any help you can give me would be great .
  2. St_ve
    St_ve
    Jan 6, 2005
    1,059
    39
    Birmingham
    Have you a decent ariel ?
    Do you use sky ,telewest cable , freeview digital or the terrestial TV ?
    Have you allready got a DVD player?
  3. riprse
    riprse
    Apr 4, 2005
    1,225
    63
    +115
    i have sky + & a sony s336 dvd
  4. St_ve
    St_ve
    Jan 6, 2005
    1,059
    39
    Birmingham
    Have you the 46 or 50" 50 L7
    I suppose the sky+ connects with scart if you're not happy with the picture quality of sky + you could try a freeview digital box to improve things.
    Component has better picture quality than Scart & HDMI is normally better than Component (Some budget DVD players with DVI or HDMI out have been reviewed in the AV magazines which found the component was better than the DVI output)
    Hope i haven't confused you more :)
  5. Razor
    Razor
    Dec 15, 2004
    37,547
    2
    +12,504
    Get a dvd player with HDMI or DVI connection.
    Sky has a RGB fully wired scart cable.
    As steve has said some dvd players have a better component pic than HDMI/DVI pic this is because they have used cheap parts for the HDMI/DVI connection. You get what you pay for.
    Spend a bit of money on leads the minimum to spend on a 1 meter lead is £35-£40, IXOS are a good make of leads. Monster cables have a bit of a bad rep and arent cheap.
    I have spent over £1000 on leads which is a fair bit but worth it. Cables are the weakest link in a system.
    Hope I have helped a bit ;)
  6. riprse
    riprse
    Apr 4, 2005
    1,225
    63
    +115
    thanks for the replys , i did get some monster leads but really didnt see any change in the picture. so i went back to comet with them and got a refund.
    so what dvd player would you buy ? i dont want to spend much more than 350 (oh its the 50" sammy)
  7. Razor
    Razor
    Dec 15, 2004
    37,547
    2
    +12,504
    You should get a good player for that money. Try the dvd forums for help. You basically need a dvd palyer that can output via HDMI or DVI. Denon or pioneer make good dvd players. Also samsung has a new dvd palyer out which is around the £200 mark. Invest in a copy of Home cinema choice and see what they recommend for the money. Or you can look at their past reviews online.
    If you want a dvd recorder please be aware that the playback on these recorders isnt as good as a non dvd recorder. I have seen £500 dvd recorders been put to shame by £150 dvd players.
  8. St_ve
    St_ve
    Jan 6, 2005
    1,059
    39
    Birmingham
    All you need is a £30 DVD player so long as it's in a PC :devil:
    You can sometimes get great bargains at Richer sounds buying discontinued stock if you do your homework properley.
    If you have an Xbox it might be worth trying with DVD's
