help with my LG 47LW450U
Discussion in 'General TV Discussions Forum' started by andy2322, Dec 7, 2011.
  1. andy2322
    andy2322
    Mar 28, 2009
    2,180
    cardiff
    +217
    Hi all :) I've had this tv for about 2 weeks and i not sure if I've got the 3D setup correct. all i did was take it out of box and started playing movies so I'm guessing it need a setup first?or maybe the films I've watched are just crap harry potter & the polar express..can someone with the same tv give me a hand setting this up please?also I've got this in the wall so is that also affecting the 3D effect?
  2. bilbosmeggins
    bilbosmeggins
    Jan 10, 2010
    4,875
    +2,936
    Difficult to tell from the picture but the tv ideally needs to be level with your seated position. Or, if not, tilted so that you are viewing it square on in the vertical plane. I have the 42" version and mine worked superbly out of the box. 3D was spot on. Only tweaked a few colour preferences, but nothing that would affect 3D performance. It has it's own thread here: http://www.avforums.com/forums/lg-forum/1393486-official-lg-lw450u-3d-led-thread.html if you are struggling
  3. Jason Shouler
    Jason Shouler
    Jan 8, 2011
    2,135
    POOLE
    +162
    Yes; unless tilted down, that TV is miles too high and the 3D will look ghastly :(
    Try standing on a chair whilst watching and it should look great :D
