Help with my JVC LT37 DS6 PLEASE!!!!
Discussion in 'LCD & LED LCD TVs Forum' started by sherbert79, Nov 1, 2005.
Tags:
  1. sherbert79
    sherbert79
    Nov 1, 2005
    171
    +4
    I bought my JVC LT 37DS6 lcd screen a few months ago and it is a great screen and brilliant to watch, however i have noticed a small black line around 5mm wide going from the top to the bottom of the screen and its just about 4 inches in from the right hand side.I have tried changing from tv to dvd to playstation however the line still remains.
    Does anyone know what this is and how i fix it?? Is this what you call screen burn??
    Scott
  2. Dan Gleebitz
    Dan Gleebitz
    Aug 18, 2005
    279
    +12
    Take it back mate! Sounds faulty to me.
    Unless... What connection type are you using?
    It sounds silly but sometimes if you don't quite push a scart lead in properly you get lots of weirdness on the screen.
  3. sherbert79
    sherbert79
    Nov 1, 2005
    171
    +4
    Im using scart leads for my digital box and my dvd, i changed the scarts over too longer ones so i could sink the wires in too the plaster so it might be them thats causing the problem.Its weird how it just all of a sudden started and its really annoying as its such a good screen!!
    scott
