Help with my denon avc-a1sr
Discussion in 'AV Receivers & Amplifiers' started by Twan1, Dec 29, 2004.
Tags:
  1. Twan1
    Twan1
    Dec 19, 2004
    1,132
    38
    Essex
    +22
    hiya all,
    I currently have a Denon AVC-A1SR amp and am planning to get a lumagen video scaler.
    Its been said that when using a video scaler you will need audio delay.
    Unfortunately my dvd player and the scaler doesnt have it and id like to know if my amp will be ok to rely on???
    Hope someone will know?????
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +14
    The A1SR should have master audio delay (the KAVC-A1SE upgrade to the AVC-A1SE offered 0-200ms delay so it should, otherwise it's a bit of a backward step)
  3. S H A D O
    S H A D O
    Mar 16, 2001
    10,280
    United Kingdom
    +1,564
    The A1SR does have it. Each input (DVD, CD etc) can have a seperate setting from 0-200ms. Bear in mind it's only an accessible option in the main Setup Menu when the sound signal you are inputting is DIGITAL or converted to digital using a mode such as Dolby PLII. No option will appear if you feed the amp an Analogue signal.
  4. Twan1
    Twan1
    Dec 19, 2004
    1,132
    38
    Essex
    +22
    thanks for your help guys, it should be ok, as it will mainly be for my dvd, though i would like to possibly use it on sky if there is a slight delay.
