Help with MR hack for my Phillips 963SA
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by jchm, Jun 26, 2005.
  1. jchm
    jchm
    Feb 6, 2002
    139
    South Notts.
    +6
    I've just bought one of these for £99 from Play (it would be wrong not to at that price....)
    After a Forum search I've tried the 'standard' MR hack using my Oneforall 6 (URC 7562), BUT it's not doing anything - the machine doesnt seem to recognise the 085 command from the remote and stubbornly just shows 'no disc' on the display....
    Using the 'Play 1,5,9' command from the Phillips RC, I do get the dashes up on the display, but when I type in '222 222 005 255', the machine locks up completely and I have to unplug it at the mains!
    Anyone with one of these last batches of 963SA's have any idea where I'm going wrong? :lease:
    John
  2. deanym
    deanym
    May 29, 2004
    1,782
    +141
    I've never tried this, but have read somewhere that 000085 works on some when 085 doesn't.
  3. jchm
    jchm
    Feb 6, 2002
    139
    South Notts.
    +6
    Cheers M8 - I finally got there with 00085, but you put me on the right track!
    I now have a lovely Region-free 963SA, and for £99!!
    John
    :clap:
  4. deanym
    deanym
    May 29, 2004
    1,782
    +141
    Excellent, glad it worked! :)
    Now check out getting the pal progressive uodate (can be found on this site and a few others) then redo the multiregion, you should be able to eke a bit more performance.
