help with mp3 transfer on hd5
Discussion in 'Headphones, Earphones & Portable Music' started by toonman, Aug 29, 2005.
  1. toonman
    toonman
    I have a few albums that are 465 bit rate. I am importing them into ss and when I transfer them to the player, I end up with a bit rate of 210. Is there a way that I can transfer them in their original bit rate??
  2. szsiddiq1214
    szsiddiq1214
    i might be wrong, but i dont think the player can handle a bit rate that high...double check the manual tho, it shud tell u
  3. myepitome
    myepitome
    The hd5 can't handle that high a bitrate...and why would you want it that high? I know for obvious soung quality, but it will drain the battery!
