Help with matching sub to Kef reference 207
grayner71
Hi All
First time on here, I am nuts about AV, in fact I spent my house deposit on hi-fi about 7 years ago, what I did not buy which I have regretted was the KEF PSW 5000 to match the 207, not to mention the 204c center speaker, music was the priority. But run this as cinema with a projector as well, which I have just updated from sim2 30H to Epson TW EH 4400, am rather blown away by the improvement and want to beef up the cinema set up.
The matching sub I cant find anymore, but the Monitor Audio Platinum PLW15 I can stretch too and has about the same spec, would this be a good match, or will the different cones be a problem, I know there are better subs but have spotted this for £1750 a the moment, I was thinking of the Jamo D600, but the Monitor has more EQ control
room is 33L*15W* 8H, Im hoping it might assist with music as the Kef 207 are a bit bass light as well
Thanks for any advice
Member 639844
Former Advertiser
I think you should think long and hard about what to add to this system. Those are pretty big speakers and you will need a good sub to really do the system quality. We do various subs that would complement the system, and we do a single 15 for £1395 with a fair bit of built in eq (5 filter slope types usable across all filters, variable high and low pass filter settings, dynamic eq control, 8 PEQ filters, low and high shelf filter types, and 20 pre-set saves which becomes unlimited via the laptop control software), but I'd be tempted to say you really want a pair to do your system justice. In all honesty, I could see adding a subwoofer into your system as more problematic for the contentment of a critical music listener, unless you do it right. That said, if you feel the mains are a bit bass light then a sub is the obvious answer, and as long as you do it right, the results will be great.
grayner71
Hi Dav1DF
They are driven by with Musical fidelity tri vista 300, tri wired, I have wondered if this maybe the issue,
Thanks for response
Member 116841
Hi Dav1DF
Thanks for response
I know the 207's aren't the bass monsters that they look, and will be a little lean compared to the likes of maybe the equivalents B&W's, but I've found that you need the right amplification to tease the bass out of them. They're efficient speakers (91dB if I recall correctly), but they like a lot of current and headroom to be able to 'be themselves'. Bryston is one of my favourite amplifiers with KEF Reference, and while I have found that the 4Bsst2 power amplifier works like a charm with the 205's, it just isn't quite enough for the 207's - they seem to work far better with the 7Bsst2 monoblocks. There may well be some slightly more pocket friendly options out there, but I haven't heard them. I had a similar issue when I owned Reference 4.2's - they sounded pretty amazing on the older 7B monoblocks, but I couldn't afford them at the time. so I had to settle for a 3B. Which sounded ok, but the level of bass halved in comparison.
Musical Fidelity used to work really well with Reference back in the 104/2 days, but that was when MF used to make some pretty serious powerhouses. Which back then, were probably more in line with their recent Titan power amplifier.
Yes, adding a sub will give you a quick, easy fix, and if that's the case, we have a Reference 208 sub available within your budget ( http://www.avforums.com/forums/18194170-post8.html ), but if your amplifier isn't getting the best out of your speakers, this won't just be affecting bass - it could be affecting the whole frequency range. In this respect, you could completely transform your speakers, and what you think they are capable of - to answer that, you'll have to get someone on home loan and see what improvements you find. If your amplifier really is doing a sterling job, then by all means research some subs. Unfortunately, I haven't heard your amp, so I can't comment on how good a job it s doing.
Member 639844
Former Advertiser
David makes a very good point, bass is really hard to produce for speakers and asking speakers to do that job, and amps for that matter, is a fairly difficult task. No doubt your speakers could probably benefit from better amplification, and bi-amping them could be one solution.
Where abouts in the country are you, we could possibly loan you a subwoofer to try in your system for a one week demo, which would allow you to evaluate your system with a subwoofer, and give you an in home demo at the same time. At least that way, you could experiment a little without spending money before your sure what you should do.
Rock Danger
I have 205/2's and a 203/2c and can get really good bass out of them, but you (and as David says) have to slap a good power amp on them.
I'm not a fan of KEF subs, which is why I have a Paradigm. That being said, it's at really good money, but I would definitely audition one of the Geko subs before deciding.
If I didn't own the sub I had now, I'd be talking to Dan Gecko for the Ultimate Sub Company or David for Ken Kriesel.
grayner71
Thanks for such great responses.
I think they can take more amplification but the amp I have is a beast see below trivista Tri-Vista
Dual Mono Integrated Amplifier, I expect more from it, to be fair it is cinema that I feel is more lacking than the music, as I think I will to fussey with tonal quality with music, I'm less discerning with cinema
Borrowing a sub for a trial does appeal, I am in East Sussex, if that works, let me know, Im happy with music, so am not going to go down the power amp root
AMP spec
Power: 350 Watts per channel into 8 Ohms (25.5dBW),
600 Watts per channel into 4 Ohms
Peak-to-peak output current: 96 Amps
Damping factor: 210
Output devices per channel: 8
Pre-output impedance: 50 Ohms
Member 639844
Former Advertiser
AMP spec
Damping factor: 210
Ye we can sort you out a free demo no problems at all. PM me your details and we'll get it sorted out for you.
Similar threads
Podcast: New TVs, Samsung Q800T Soundbar review, IFA latest, Movie and AV News, B+W Brad Pitt
