Help with Marantz PM7200
Discussion in 'AV Receivers & Amplifiers' started by higenbs1, Nov 24, 2003.
Tags:
  1. higenbs1
    higenbs1
    Aug 16, 2002
    460
    +11
    Recently purchased a PM7200, and was wondering about how to connect to speakers. There are 4 sets of speaker terminals on the back of the amp (A, B, A+B), and I was going to biwire to my front speakers. I thought the easiest way of doing this would be to connect to all four sets and always run the amp on A+B.
    Is there any disadvantage in sound quality im doing this? Also, does the Class A mode work across both sets?
  2. puddleduck
    puddleduck
    Jan 24, 2003
    1,853
    48
    Lake District, near as dammit
    +59
    what you are suggesting is bi-amping, not bi-wiring.
    I doubt you'll see any improvement from this set-up too be honest though....
    Class A makes no difference to sound quality at all.
  3. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    How can it be bi-amping, that would need 2 amps not 1 with 2 speaker outputs.In answer to your question i would use the a terminals just marked (A) because the other will be switched.
  4. puddleduck
    puddleduck
    Jan 24, 2003
    1,853
    48
    +59
    yep you're right - thought that after I posted, but didn't get round to edited it :)
