Help with M&K K4s please
Discussion in 'Home Cinema Speakers' started by rb5201, May 11, 2005.
  1. rb5201
    rb5201
    Apr 20, 2005
    2,112
    63
    essex
    +214
    I have M&K5s for the front sound and K4s for the rears. Am confused as to which speaker is the left and which is the right. As they are going to be behind me is the left one the one behind me as I sit or as I look at it. Each speaker has an arrow on it at the back, should these be facing each other or facing the walls?
  2. PeterKay
    PeterKay
    They should be facing each other.
  3. 30CenturyMan
    30CenturyMan
    Dec 3, 2004
    924
    46
    +114
    The K4s are designed to be mounted to the side of the listening position. The arrows are there to indicate the direction of the front soundstage and screen. :)
  4. KHCC
    KHCC
    Aug 10, 2004
    256
    Kent
    +10
    Mornin'
    We have the K series package on in demo room 3, basically the left rear is to be placed on the left hehind you as you face the front 3 and the screen and the same goes for the right rear. It is important as the side drivers are put inphase with the appropriate front left and right.
    Hope this helps.
  5. S H A D O
    S H A D O
    Mar 16, 2001
    10,438
    United Kingdom
    +1,820
    As Scott3 has said. The K4's should be positioned to the side of the main listening area (seeing as they're Tripoles).
