Help with location of Subwoofer
Discussion in 'Subwoofers' started by pat 2800, Nov 30, 2004.
  1. pat 2800
    pat 2800
    Can anyone see a problem locating an active sub under the TV ?
    Will it cause picture distortion or possibly damage the TV ?
    I had a passive sub under an older telly for years with no problems.
    All comments welcome.
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Depends on the type of sub along with the distance and angle from the TV. I'm afraid there's no straight answer unless the sub is shielded. If it's shielded it's fine, if not you may have to play a bit.
  3. Pat Marcus
    Pat Marcus
    Oct 29, 2004
    610
    Ibstock
    +8
    mines very close to the TV and there isnt a problem.
  4. Pat Marcus
    Pat Marcus
    Oct 29, 2004
    610
    Ibstock
    +8
    Do you know about the principle of locating a sub in a room "node." It does make a difference if the layout of your lounge is not the dictating factor about where the sub has to go.
