Help with LG Oled wall mount bracket
aandpwoodley
I need some advice please.
I have the official LG wall mount bracket OTW420B which is Vesa 400x200, 300x200
The new TV I'm looking at is 400 x 400.
Can you get a conversion plate or something so I can use my existing mount ?
aandpwoodley
Are there any other options available ?
aandpwoodley
Bump, anyone have any other ideas please
jakey
Dunno what you expect to find better, the brackets I linked to will do the job perfectly.
The picture below show the the brackets fixed to my previous Philips Oled, they are fixed to the vesa holes on the TV then the LG stud things fix to the brackets as you can see in the picture which then just hang as normal onto the OTW420B. Solid and neat solution.
aandpwoodley
That makes perfect sense now, thanks.
aandpwoodley
I'm going to use the same wall bracket on either the 77"CX or C1, it's the LG OTW420B which is compatible with Vesa 400x200, 300x200
Does anyone know if the fixing holes on the back on the CX/C1 are in the same or similar place to the E6.
I'm hoping I don't need to adjust the height of the existing wall bracket.
Hope this makes sense
Andy
Podcast: Sony A90J Thoughts, madVR Processor & Sonus faber Lumina II Reviews + Movie & TV roundup
