Help with Kef Egg Stands Which ones
Discussion in 'Home Cinema Speakers' started by mwallan, May 31, 2003.
  1. mwallan
    mwallan
    Jan 20, 2003
    981
    +78
    :clap:
    I need some help with the selection of speaker stands for kef eggs. As I understand it the official stands are not that good is this true ???
    If so what do people recommend?:smashin: :confused: :rotfl:
  2. oggy
    oggy
    Feb 5, 2002
    236
    Turriff
    +6
    The Kef Egg stands are crap to put it mildly.Mount them on the ceiling instead.:smashin:
  3. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    Crumbs you must be tall - I've always been told to mount the front speakers at ear height sitting down.
    BTW the egg I use for the centre rear is just screwed to the wall - looks/sounds fine and appears pretty solid
  4. mwallan
    mwallan
    Jan 20, 2003
    981
    +78
    the walls sounds good, but im not able to do that in this flat !!! due to the landlord, things will be different when i buy a house .....
    With that in mind what stands do you rec for the kef eggs
  5. gingerone
    gingerone
    Dec 10, 2002
    2,404
    +289
    The kef stands are crap but the mount ensures that no others will fit.
  6. villaceltic
    villaceltic
    May 22, 2003
    84
    Nantwich, UK
    Yeah, Ok great, they're crap - but seriously what alternative is ther short of srewing them to the walls?
    Macca
  7. oggy
    oggy
    Feb 5, 2002
    236
    Turriff
    +6
    Point them down to where the listening position is sorted nae problem by using a pair of steps !:clap: :rotfl:
  8. Sunday Ironfoot
    Sunday Ironfoot
    Do the Keff have a flat bottom?
    If so consider something like Atacama Nexus 6 (£60) or Partington Dreadnought (£100), the latter are particularly liked by What HIFI.
  9. oggy
    oggy
    Feb 5, 2002
    236
    Turriff
    +6
    Yes they have a flat bottom unlike my missus who has a looooovely bottom:smashin: :kisses: :kisses: so i guess you could mount them on a majority of stands or shelves etc etc.
  10. Sunday Ironfoot
    Sunday Ironfoot
    What!? Your wife or your speakers? :smoke:
    Anyway the answer is yes, remember to buy some dry sand to fill them with, use blue-tack to attach your speakers to the stand.
