Help With Kameleon 4 In 1
Discussion in 'Home Cinema Control & Remote Controls' started by bigjonnyauk, Sep 14, 2004.
  1. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    726
    midlands
    +16
    HI ALL
    picked up a 2nd hand kameleon on the cheap yesterday should come friday but i hear the older ones may not have codes for newer stuff
    anyone know codes for the following please
    toshiba television=32z44 came out about 7 months ago
    toshiba sd220 dvd player
    NTL pace di4001n cable box (no idea about this one)
    thanks if anyone can help be great
  2. Solar
    Solar
    Dec 2, 2003
    2,541
    Earth
    +477
    toshiba tv codes - 0508, 0036, 0217, 0109, 0195
    toshiba dvd codes - 0503
    ntl pace codes - 0455, 0847, 0887, 1175, 0241, 0867, 0791, 0720, 0497, 0200, 0853
    these codes are 1 month old so they should work :)
    the remote itself has some kind of built in modem and can be upgraded to work with newer model equipment for free through their site
    http://www.oneforall.com
  3. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    726
    midlands
    +16
    the 4 in 1 dosent have the upgrade option does it only the 6 in one when i put the codes in do i need to put them all in or just one of them
