Help with ISO game files
Discussion in 'PS Vita Forum' started by BuFF DaDDy, Oct 5, 2005.
Tags:
  1. BuFF DaDDy
    BuFF DaDDy
    Jun 2, 2005
    3,297
    +146
    Ive unrared the file and its now as above. all the guides say I need to put the ISO file on the PSP, but as you can see there isnt one.
    Do I have to put sysdir and usrdiron the psp?
    Any help would be appreciated, this is driving me mad!! Just to confirm that its the Spiderman 2 ISO game and I have the original.
    Heres what the contents of the PSP folder looks like when I unrared the file.
    [​IMG]
  2. Fatbob1080
    Fatbob1080
    Oct 3, 2004
    655
    28
    Fareham
    +46
    Nope, assuming youre using umdemulator 0.8c you need to create a folder called iso on the memory stick and copy the iso into it, you dont need to extract the files from it... :p
  3. BuFF DaDDy
    BuFF DaDDy
    Jun 2, 2005
    3,297
    +146
    LOL
    So the file goes in zipped?
  4. Fatbob1080
    Fatbob1080
    Oct 3, 2004
    655
    28
    Fareham
    +46
    Should be 1 file youre copying on there ending in .iso ... yep :)
  5. BuFF DaDDy
    BuFF DaDDy
    Jun 2, 2005
    3,297
    +146
    You know what, I could kiss you sometimes Fatbob!
    :smashin:
  6. Fatbob1080
    Fatbob1080
    Oct 3, 2004
    655
    28
    Fareham
    +46
    Eurk! :laugh: Thats ok. No need to get carried away or anything! :hiya:
  7. BuFF DaDDy
    BuFF DaDDy
    Jun 2, 2005
    3,297
    +146
    LOL Thanks man!
  8. chrislad
    chrislad
    May 6, 2005
    5,816
    83
    Rep. of Ireland
    +145
    Your inbox is full, Buff, but you're good to go. The fact that the iso is associating with WinRAR has no consequence.
  9. BuFF DaDDy
    BuFF DaDDy
    Jun 2, 2005
    3,297
    +146
    Just deleted some old messages thanks for the heads up, cheers chris appreciate your help and advice also mate.
