Help with iPod Shuffle and connecting to a PC
inzaman
I have been trying to get an iPod Shuffle connected to my PC but i just dont think it is being recognised, or something is wrong? I have the latest version of iTunes installed and when i connect the shuffle i get the following message;
"The iPod "Offline" cannot be used with iTunes because it was not formatted properly"
"To format this iPod so that it can be used with iTunes, go to the Summary tab in iPod preferences and click restore"
I click okay and it goes directly into the iPod summary tab, i then click Restore - that is the only button that it allows me to click. It then goesd through a retore routine and tells mt that it has been restored and rebooted. When that has done i get the above message again. Can someone please help :lease:
My pc is runing Windows XP and this does not recognise it as a flash drive etc??
inzaman
I have also run a diagnostics test i iTunes and get the following regarding the iPod
Microsoft Windows XP Professional Service Pack 2 (Build 2600)
TOSHIBA PORTEGE S100
iTunes 7.5.0.20
CD Driver 2.0.6.1
CD Driver DLL 2.0.6.2
Current user is an administrator.
The current local date and time is 2008-01-12 17:11:28.
Video Display Information:
NVIDIA GeForce Go 6200 TE 64M / 6600 TE 128M
**** Network Connectivity Tests ****
Network Adapter Information
Adapter Name: {32B949A4-F6CE-410E-A15F-562BB1FA79FD}
Description: USB Cable Modem 351000 #3 - Packet Scheduler Miniport
IP Address: 82.17.93.204
Subnet Mask: 255.255.252.0
Default Gateway: 82.17.92.1
DHCP Enabled: Yes
DHCP Server: 82.3.32.36
Lease Obtained: Sat Jan 12 16:31:29 2008
Lease Expires: Wed Jan 16 18:19:44 2008
DNS Servers: 194.168.4.100
194.168.4.100
194.168.8.100
Adapter Name: {B01CA14C-AB08-4ABE-9AA2-17D8509B9686}
Description: Intel(R) PRO/Wireless 2915ABG Network Connection - SecuRemote Miniport
IP Address: 0.0.0.0
Subnet Mask: 0.0.0.0
Default Gateway:
DHCP Enabled: Yes
DHCP Server: 192.168.0.1
Lease Obtained: Wed Jan 09 18:16:25 2008
Lease Expires: Sat Jan 12 18:16:25 2008
DNS Servers:
Adapter Name: {AF581574-24B3-4A2E-BD83-71BA28650A76}
Description: Marvell Yukon 88E8053 PCI-E Gigabit Ethernet Controller - SecuRemote Miniport
IP Address: 0.0.0.0
Default Gateway:
DHCP Enabled: Yes
DHCP Server: 57.201.102.46
Lease Obtained: Fri Jan 11 08:54:15 2008
Lease Expires: Fri Jan 18 08:54:15 2008
DNS Servers: 57.201.102.48
57.201.102.48
57.201.102.46
Adapter Name: {90678A44-BA04-444D-BB97-665457C3365F}
Description: Juniper Network Connect Virtual Adapter
IP Address: 0.0.0.0
Default Gateway:
DHCP Enabled: Yes
DHCP Server: 255.255.255.255
Lease Obtained: Wed Dec 19 17:16:39 2007
Lease Expires: Wed Dec 19 18:16:39 2007
DNS Servers:
Active Connection: LAN Connection
Connected: Yes
Online: Yes
Using Modem: No
Using LAN: Yes
Using Proxy: No
Firewall Information
Windows Firewall is off.
Connection attempt to Apple web site was successful.
Connection attempt to iTunes Store was successful.
Secure connection attempt to iTunes Store was successful.
Secure connection attempt to iPhone activation server was successful.
**** iPod Connectivity Tests ****
iPodService 7.5.0.20 is currently running.
iTunesHelper 7.5.0.20 is currently running.
Apple Mobile Device 1.14.0.0 is currently running.
Universal Serial Bus Controllers:
Intel(R) 82801FB/FBM USB Universal Host Controller - 2658. Device is working properly.
Intel(R) 82801FB/FBM USB Universal Host Controller - 2659. Device is working properly.
Intel(R) 82801FB/FBM USB Universal Host Controller - 265A. Device is working properly.
Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C. Device is working properly.
FireWire (IEEE 1394) Host Controllers:
Texas Instruments OHCI Compliant IEEE 1394 Host Controller. Device is working properly.
Most Recent Device Not Currently Connected:
iPod shuffle (2nd & 3rd Generation)
Serial Number: 4H739QERYX6
:lease:
spooney
Same happened to me after I ordered one for my wife. I tried everything until I found out Apples is aware of this problem.
Go the Apple support page and search for the iPod reset tool.
This is a Windows stand-alone tool and the reqired steps are well documented.
It will do more then just the iTunes reset.
My wife's shuffle is working great since then.
inzaman
Thanks i will give that a go :)
