Help with Internet Explorer 7 plz
Discussion in 'Desktop & Laptop Computers Forum' started by chaz206, Feb 9, 2009.
  1. chaz206
    chaz206
    Jan 6, 2008
    1,158
    38
    +19
    Hey there people, just installed IE 7 (going to still install Windows Service Pack 3)
    and have to say it's very diff using it on my own pc rather than other peoples, lol
    But 1 prob is each time i open a window or tab a small bar comes up saying:
    your current security settings may put your computer at risk, etc...
    you can click on the cross, but its p*****g me off as its coming up every single time
    Any way to stop it coming completly, and no i don't want to change my settings, plz
    Also people any way i can move the address bar a bit lower to where it used to be and move the file, edit buttons back up??
    Any help plz people, cheers
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,474
    2
    +1,367
    IE tools, options, security, set each of the 4 icons to DEFAULT.
    Also in "general", Tabs, set the first 6 tick boxes. And the dropdown to "Your first home page".
    Should now run a lot smoother.
  3. chaz206
    chaz206
    Jan 6, 2008
    1,158
    38
    +19
    cheers andy, but tbh i dont really want to change any of my security settings mate, i've set them as such, lol
    Any other way?
    And cheers for the other advice trying different ways to get it smoother or even exactly how i want it to run
  4. Fe_man2000
    Fe_man2000
    Mar 27, 2005
    1,507
    63
    North Somerset
    +220
    think you might be stuck with it then
    message - "your current security settings may put your computer at risk, etc..."
    but you dont want to change your security settings....
    I dont think it can be disabled any other way. Which part of the security settings are you refusal based on - maybe theres a way to set them specifically.
  5. andrewt9763
    andrewt9763
    Jul 9, 2006
    3,171
    +443
    Right click the box and open the security panel,check the box I have a firewall/security solution I will monitor myself.This should stop it but would not advise internet use without some kind of firewall/antivirus running
