Help with Interconnects Sky Video DVD
Discussion in 'Cables & Switches' started by Bales1983, Jun 15, 2004.
  1. Bales1983
    Bales1983
    Hi all,
    Just ordered a Sanyo 32WN5 TV, I also have a Goodmans HEC17 Home Theatre Kit coming too, I need a little help with wiring, the TV has 2 scart sockets but only 1 RGB enabled (i think so anyway?), So its obvious sky box has to go to scart 1, and dvd can plug into the other scart on the Sky box and should pass through?, So we have DVD > Sky> TV1 and on scart 2 we have VCR > TV2, thats good but need to record from sky so i would need VCR > SKY > TV1, and DVD > TV2 but scart 2 isnt capable of using RGB? Any ideas on what i can do??
    TV = 2 scarts
    Sky = 2 scarts
    DVD = 1 scart
    VCR = 1 scart
    Hope someone can help,
    Lee
  2. Parklife
    Parklife
    Jun 9, 2004
    574
    28
    +33
    My personal choice would be to have the DVD going to Scart 1 (RGB) and then having sky to Scart 2 and sky - video.
    You could of course get a scart switcher which allows you to have more than one output going to one input and have both Sky and DVD going into Scart 1. Vivanco do a manual scart switcher for about £20. There are others and auto switchers out there.
    Hope this helps
  3. Teleport
    Teleport
    Why are you trying to get RGB to your VCR Lee?
    Will your VCR accept RGB?
    My advice would be to keep your current setup and just plug your VCR into Scart 2.
    As your TV has 2 scart sockets it should also have the facility to pass whatever is comming in scart 1 onto scart 2 so the below will be your setup
    DVD->SKYBOX->TV<->VCR
    Oh and if your DVD has a pass through I would put it ahead of your SKYBOX if possible as the DVD has the better picture that you don't want degrading while being passed though the SKYBOX. But this is up to you.
    Hope this helps.
  4. nikyzf
    nikyzf
    Assuming TV SCART1 is RGB, I'd go
    DVD > SCART1
    Sky > VCR > SCART2 (or VCR > Sky > SCART2)
    That way DVD has a direct path to RGB, whilst allowing the VCR to record Sky as normal.
